Re: Super-H-charging system
Posted by Glen Swanson on November 05, 2007 at 07:50:01 from (172.129.239.183):
In Reply to: B-charging system posted by jakey756 on October 30, 2007 at 17:16:18:
I went thru all of the test for charging and at the end when I grounded the field it started to charge. You indicated that you could leave the jumper on (ground field) if you are not doing heavy laber, I live in New Hampshire and use it to plow snow, will the jumper damage anything when using the tractor like this?? It is fully pegged on the charging side, should I invest in a new regulator and if so are there any special steps since this is the second regulator.
thanks
Glen
