Re: 706D leak in fuel return lines
Posted by the tractor vet on November 05, 2007 at 08:07:43 from (99.167.217.149):
In Reply to: 706D leak in fuel return lines posted by GeneMO on November 05, 2007 at 05:05:31:
If you are talken about the return line on a 310 german diesel there are two copper washers used on each injector . IF that is where it is leaking at the banjo fitting then maybe you can snug them down a bit but DO NOT get carried away as the bolts are hallow and one can twist them off . IF the line is leaking then your going to have to bit the bullet and get a new line and washers .And now you will not have to bleed the system when working on the return line.
