Re: SA hydraulic pump seal question - where does leaking oil
Posted by SteveNH on November 05, 2007 at 11:57:04 from (149.32.254.242):
In Reply to: SA hydraulic pump seal question - where does leaking oil go? posted by SteveNH on November 04, 2007 at 06:50:00:
I will look at adjusting the stop clips this week. Might be it - not sure. I can get the pump to quite down at idle when moving the levers up and down a little but when I increase the RPM"s or after a few minutes at idle it whines again. Probably a good idea to make sure it is adjusted properly anyway.
Thanks.
