Re: ...FARMALL 656 Diesel - 1966 - Power Steering...
Posted by Owen Aaland on November 05, 2007 at 12:29:56 from (65.174.247.81):
In Reply to: Re: ...FARMALL 656 Diesel - 1966 - Power Steering... posted by Shawn Alfonsi on November 04, 2007 at 21:17:12:
The foamy oil is an indication of air in the oil. Air in the oil may cause the problems you are having. You need to address that problem before you start taking apart pumps or steering parts.
First check to make sure you have the correct amount of oil in the transmission. Make sure the filter is clean. If you still have bubbles, try adding an additional five gallons of oil to see if the makes the problem go away. If you still have the problem, you may have a leak in the hose between the hitch drain and the oil pickup tube.
