Re: crank pounding M
Posted by Nebraska Kirk on November 05, 2007 at 17:28:25 from (207.91.30.80):
In Reply to: Re: crank pounding M posted by Nat 2 on November 05, 2007 at 13:08:01:
You don"t have to remove the engine to replace main bearings. Just loosen all the main bearing cap bolts, take one bearing cap off at a time, take a flat screwdriver and push against the upper bearing shell and it should roll out, it sometimes helps to turn the crank as you are pushing against the bearing shell. Install the new shell the same way.
