Posted by PL on November 05, 2007 at 17:35:08 from (72.9.75.92):
In Reply to: Re: D282 engine posted by Too Far Gone on November 05, 2007 at 07:45:42:
Thanks for the help, took the return line loose, not much fuel coming out of the pump. Unscrewed the fitting out of the pump and check valve was clear. Put a hose connection on the pump return started engine it ran great, after 3-4 minutes of run time shut down and looked in the bucket where I had put the return line, small black piece of look like gasket material(appears it was floating around and plugging return line check). Now how did that get in there ??????????thanks again PL
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
