Second is a sliding straight cut gear with a matching gear on the counter shaft. When put in gear, the teeth mesh across their width. For it to pop out, four things may be found to be either the whole cause, or partial contributor. 1) the second third shifter fork could be bent and not getting it into 2nd all the way. (pull cover to fix) 2) The detent ball and spring on the 2/3 shift rail may be frozen, weak, broken. Pull cover to fix 3) the teeth may be ground off to a bevel allowing it to want to come out of gear. Replace gears on output shaft, and lay shaft. Pull cover, pump, and disassemble trans to the basic case. 4) bearings may be out of the 2/3 slider allowing it to be forced crooked on the shaft. Same as #3
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
