Posted by Janicholson on November 05, 2007 at 18:41:39 from (66.173.50.107):
In Reply to: 1954 SH posted by george pickering on November 05, 2007 at 16:49:09:
Yes. THe position ot the drive (from pump to distributor must be as it was. How to get there. Pull #1 plug and turn the engine till it blows your thumb out of the hole. (slow bumps on starter) then put a piece of copper wire 8" long into the hole to feel for TDC. Rotate until almost to the top and then look at the pulley timing marks. Set it at TDC. Pull the pump with the distributor on it out of the hole and turn it so the rotor points to the 1:00 o'clock position when the pump is in all the way. Some trial is needed due to the spiral (helical) cut of the gears. Then bolt it together and re time the ignition as in the book. You are then good top go. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
