Re: winterizing tractor- don't forget rear tire fluid!
Posted by old on November 05, 2007 at 21:03:00 from (4.244.220.239):
In Reply to: winterizing tractor- don't forget rear tire fluid! posted by K.B.-826 on November 05, 2007 at 19:39:19:
If the fluid does freeze it can do a number of things. ! is to rip the tire apart, 2 brake the rim, 3 just take out the tube. Now yes if you have most of it out you might be ok but whats left could still freeze and that might take out the tube. What I would do is put in some WWF or Antifreeze just to be on the safe side
