Re: Transmission countershaft nut
Posted by Michael Soldan on November 06, 2007 at 08:01:09 from (24.235.46.3):
In Reply to: Re: Transmission countershaft nut posted by Southern Ray on November 06, 2007 at 06:42:45:
Its called a "speedy sleeve" made in todays wearable plastic(nyrophrene), it slides over the worn shaft and then your seal is installed and it makes the fix. Carquest/Napa/most auto supply and farm supply shops will have them.
