Posted by Bob M on November 06, 2007 at 08:36:44 from (151.190.254.108):
In Reply to: Current Drain on 43' H posted by Wisconsin_Joe on November 06, 2007 at 06:10:06:
Wisc Joe –
First off, the test where you remove the battery cable then insert a voltmeter between the battery post and the cable is gonna show only battery voltage. It cannot measure leakage current draw! (You are merely measuring the voltage between the battery positive and the rest of the system.)
A reading of 12.6 volts is exactly what you should see. Further, a reading of 3 volts after you disconnect the wire from the BAT terminal is about what I’d expect. (Actual reading will depend mostly on the internal resistance of your particular voltmeter)
Rather, to measure leakage current you must set your meter to the DC current mode, then connect it between the battery post and the disconnected cable. Start with the meter at it’s highest current setting (usually 10 amps) then work downward one currently increment at a time until the meter begins indicating. And ABSOLUTELY DO NOT turn on the any electrical loads (ign switch, lights, etc) while doing this test!! (Fail to observe this and you risk smoking your meter!)
For a generator-equipped system the current draw under this test should be almost 0 milliamps, even with the meter set on the low milliamp range.
However for a alternator, standby draw could run as high as 10 – 20 milliamps and still be OK. Readings higher than this usually mean a bad regulator or a problem (a failing diode) inside the alternator.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
