Re: Transmission countershaft nut
Posted by Bob M on November 06, 2007 at 08:45:47 from (151.190.254.108):
In Reply to: Transmission countershaft nut posted by neblinc on November 06, 2007 at 06:14:16:
There's even an easier fix:
The new seal you buy will be about 1/2 the thickness of the original seal you removed. When installing the new seal, drive it into the retainer just far enough so the new seal lip rides BETWEEN the two grooves in the nut. It will now seal the just like new,
I would however recommend chucking the nut in a lathe, then using FINE emery cloth to deburr the wear grooves and to lightly polish the unworn sealing surface between the two grooves on the nut before putting it back on.
