Posted by glennster on November 06, 2007 at 09:12:02 from (76.224.26.7):
In Reply to: Carb leaking on M posted by JDZ on November 06, 2007 at 08:39:56:
there is a drain on the bottom of the carb for just that purpose. get in the habit of Always shutting of the gas when you stop the tractor. usually a little bit of dirt will cause the float to stick and you get a streamer!!!. at 3 dollars a gallon, its a lot cheaper to turn the fuel off.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
