Re: Carb leaking on M
Posted by Bob M on November 06, 2007 at 09:21:21 from (151.190.254.108):
In Reply to: Carb leaking on M posted by JDZ on November 06, 2007 at 08:39:56:
The opening in the bottom of the air inlet is a drain to let accumulated gas out should the carb flood.
There's supposed be a small felt filter "button" retained by a stamped sheet metal washer pressed into the opening. With the filter button is missing it will let a small amount of unfiltered air into the carburetor when the engine is running - not a big deal unless you use the tractor a lot under dusty conditions.
Note that plugging the opening solid can result in filling the air cleaner and the engine cylinders with gas should the carb float fail!!
