Re: Need Help
Posted by old on November 06, 2007 at 09:47:26 from (4.244.6.107):
In Reply to: Need Help posted by EH in KS on November 06, 2007 at 07:31:47:
Just to add to what the others have said. You also need to pull the drain plug out of the bottom of the carb and make sure you have a god steady flow of gas there. You may have a good steady flow at the line but not the carb and if thats true then it still will not run. 5 minutes says either a fuel problem or a bad condenser either one or both can cause that problem. Now if you said it would run an hour then it would probably be the coil. Oh and it could also be an ignition switch going bad. Check for fuel flow and also check for a good blue/white spark when it dies. Then go form there
