Re: Transmission countershaft nut
Posted by Haas on November 06, 2007 at 14:08:42 from (12.65.48.164):
In Reply to: Transmission countershaft nut posted by neblinc on November 06, 2007 at 06:14:16:
I put a Speedy Sleeve on to fix a friends Super H. No leaks so far and that was a couple years ago. If you have a Motion Industries supply house near you, they can get the speedy sleeve. I think you could also get one at NAPA or similar parts place. Need to have someone that can measure the part and get you the correct sleeve. The Speedy Sleeves are not cheap. As I recall the one I got cost around $25. They come with an installation tool. I think the sleeve or turning down the part on a lathe is better than trying to position the seal so it runs on a good spot on the shaft. You can also probably still get this part through an IH dealer, but that won't be cheap either.
