Re: 1942 H
Posted by Andy Motteberg on November 06, 2007 at 14:30:16 from (4.143.222.44):
In Reply to: 1942 H posted by G.V.J. on November 06, 2007 at 13:46:56:
If you put in new pistons or rings, you may need to put a small amount of engine oil in each cylinder and slowly crank the engine a few times.
Good luck
