Re: 1942 H
Posted by D Slater on November 06, 2007 at 16:06:42 from (71.164.57.221):
In Reply to: 1942 H posted by G.V.J. on November 06, 2007 at 13:46:56:
Did you check compression with throttle closed or wide open? Did you have the timing gears removed? If so camshaft could be out of time with crankshaft. Also could the valves be adjusted to tight. Did you stager the ring gaps? Were the pistons replaced? Probably didn't happen, but there's a outside chance the pistons could have been manufactured with the wrong compression height. Also check to see if spark plugs are getting wet.
