Posted by Janicholson on November 06, 2007 at 16:56:54 from (66.173.50.169):
In Reply to: '43 H clutch posted by dan.160 on November 06, 2007 at 14:56:08:
Simple, or complex. It depends on thie following action. Go to the tractor with a measuring tape, or ruler. with your hand, push in on the clutch pedal until it changes its feel to be much harder to push. (from easy to hard) When it is at that spot, measure between the casting of the top of the trans (platform) and the spot on the pedal that touches the platform when the clutch is not being pushed. It should measure 1 to 1-1/4 inches. This is freeplay, and is necessary to keep the fingers off of the throwout bearing when the clutch is not pushed. Adjust the length of the rod connecting the pedal to the arm on the housing to make this measurement correct. If it is correct, the tractor will need to be split to repair the clutch Pressure plate (by replacing it) it may have cracks or warpage that prevents proper disengagement. Good luck, it is probable that the adjustment will do the trick. Heat the turnbuckle if it is frozen, they do get rusty. JimN
Today's Featured Article - Women and Tractors - More Views From the Farmer's Wife - by Teri Burkholder. The top ten reasons why the judges wouldn't let you participate in the stock antique tractor pull: Hey, this is stock! It came with that V8 in it! That "R" on my tires stands for "really old" not radial! Blue gas? We thought it was a pretty color! What wire hooked to my throttle?
... [Read Article]
Latest Ad:
[More Ads]
