Posted by gene bender on November 07, 2007 at 02:26:22 from (67.55.226.214):
In Reply to: 1942 H posted by G.V.J. on November 06, 2007 at 13:46:56:
You say the mag is timed are you sure the rotor is pointed at the tower on the cap when it impulses. You can have fire to the plug but that doesent mean the fire gets to the plug when piston is TDC. Are you sure the timing marks are correct cause if you are out then the compression would be low or is your guage bad.40 seems like awful low reading especially with new rings. I would remove all plugs. Turn engine over till piston is on top TDC then check iff both valves are closed. Do this on all 4 cycls to double check. Hope this helps
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
