Re: engine oil
Posted by dhermesc on November 07, 2007 at 05:49:33 from (24.248.193.103):
In Reply to: Re: engine oil posted by bunghammer on November 06, 2007 at 20:09:30:
More likely then not the "the plain old 30w" had the same/similar amount of sulfated ash as the advertised Low Ash 30W IH oil. Quality brands such as Castrol GTX actually have less sulfated ash then the IH oil, Penzoil has the same and other lesser brands have slightly more. While the IH oil is of good quality its a bit deceptive the way they harp on about their "low ash" quality.
Remember low bidder fills the IH bottles.
As mentioned below low ash oil is only for gas tractors, diesel engines need the higher sulfate ash levels.
