Re: Farmall rear lights
Posted by Hugh MacKay on November 07, 2007 at 06:48:18 from (209.226.106.8):
In Reply to: Farmall rear lights posted by Dave H (MI) on November 07, 2007 at 06:31:41:
Dave: Each of my SA, 130 and 140 are different but in all cases it is still a red lense over a white bulb. My SA and 130 each a bit different but in both cases a small light with red lense set into cone of main lamp. My 140 is sealed beam with red back and a white bulb behind the sealed beam. Basically all that happens with that one you switch off the sealed beam and the white bulb behind lights up.
Since I switched the 140 to 12 volt, I am not able to find 12 volt sealed beam with red back. I notice the newer 12 volt 140 s have separate red lights on each fender and flashers as well.
