Re: Update on H Not Starting
Posted by El Toro on November 07, 2007 at 07:03:26 from (64.12.116.73):
In Reply to: Update on H Not Starting posted by Farmall Ed on November 07, 2007 at 06:54:08:
Your mag doesn't need battery voltage, it is required on a distributor. Hal
PS: If you ran battery voltage to a mag you will fry the coil unless your mag has been converted to a distributor.
