Re: Update on Loose 240 U Steering Problem
Posted by DAVE240 on November 07, 2007 at 08:58:53 from (24.213.190.134):
In Reply to: Update on Loose 240 U Steering Problem posted by PaulW_NJ on October 25, 2007 at 17:03:43:
i did get everything apart! i have the same problem, not as bad as yours. my woodruff key was sheered off... shaft had light score marks on the taper shaft. i needed a puller to get the pittman arm off. we cleaned up the shaft and pittman arm, the woodruff key way was not messed up. i replaced the key, all back together. time will tell the story. i have alot of other work to do on it before it can be used again.
