Re: Sparks and more sparks!
Posted by old on November 07, 2007 at 12:00:01 from (4.244.186.147):
In Reply to: Sparks and more sparks! posted by jake w on November 07, 2007 at 11:54:22:
If it was just the ignition switch you would only get small sparks but if its the starter button you will get big sparks and the engine should try to turn over. I would pull the cable off the starter and then try again. If you get no sparks then you know its the starter button
