There are several possible problems. A 51 super C has (from the factory) a 6volt positive ground system. with a generator, voltage regulastor, amp gauge, and a starter switch using a rod to mechanically connect the contacts inside (at the starter). If yours has had an alternator put on it from a automotive/truck application, it will (most likely be 12 volt negative ground.
If you put the battery in incorrectly, with either system, turn it around.
If the sparks were serious and you left it connected, things may be toasted a bit and need some diagnosis. The ignition switch can go bad, but it usually fails by not working, not by staying on. THe sparks fron the ignition being on would not make you excited they would be mild little sparks. Let us know if you have an alternator retrofit, or stock system, or what. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
