A general comment on books that claim to give the complete history of this or that. I have a number. Some are better than others. Some appear to have been written by people who were never around the "real old stuff" (20s, 30s, 40s). Here and there, I find statements that are in error. For example, several writers call the original Farmall "Regular." Lots of people did. I used to hear, "She ain't a F-20, she's just a regular Farmall," and that is exactly what they meant--the "ordinary, original Farmall". But....IHC never did, as best I can tell. I have several IHC brochures from the 30s and 40s, and they tend to say, or at least suggest, that any Farmall is "descended from the original Farmall." Another thing I have seen at least once, and maybe more often, is that the F-20 is a "bigger Regular." Not so--it's basically the same machine, but with a 4-speed transmission, an updraft manifold, and enclosed steering gear (2 types--the worm-gear type being the most widely-produced). I've spent a lot of time on both, and there is not a lot to distinguish them. The Nebraska tests show a considerable difference in power between the two tractors, but the early-model Farmall tested had a 1" venturi; later models went to 1-1/4, the same size as the F-20. The Farmall I used to use would pull the same load as the F-20--two 14s in second gear, or a 7-foot double disk harrow. My message is: If you are looking for an overview, fine. If you are looking for absolute truth...don't believe everything you read--check around. By the way, I have seen similar mis-statements in books about automobiles. I suspect that the writers have pre-conceptions and don't follow them up enough to see if what they believe is true.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
