Posted by glennster on November 07, 2007 at 18:51:02 from (68.60.242.156):
In Reply to: 'M'ore tranny help posted by Carden on November 07, 2007 at 14:53:50:
i use kerosene to flush them too. if the tractor is a runner and a driver, do like scotty said, drain some out and add kerosene. anywhere from 3-5 gallons is fine. then run the tractor around without a load on it for a half hour or so. wouldnt hurt to run in each gear for a little. that will stir up the oil and thin it. then drain the oil. sometimes you need to dig around in the drain hole with a piece of wire to get the goo loose so it drains. i will at this point flush it a few times with 5 gallons of kerosene. when you pour it thru, strain the kerosene with a paint straining funnel and use it again. when done let it drip for half a day, then refill with gear lube.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
