Re: cub vs. 350 attachments
Posted by Nat 2 on November 08, 2007 at 07:20:16 from (64.80.108.53):
In Reply to: cub vs. 350 attachments posted by Cris on November 08, 2007 at 06:52:26:
All Cub implements are specific to the Cub. They will not fit any other tractors, period.
I suppose you could hack up the tiller with a torch and welder, but the 30HP 350 will tear it apart, as it is only designed for an 8HP tractor. You will also be tearing up a VERY rare and valuable piece of equipment.
If the tiller is in good condition and relatively cheap buy it and resell it for a huge profit.
