Posted by Sagebrusher on November 08, 2007 at 07:26:35 from (66.82.9.58):
In Reply to: 'M'ore tranny help posted by Carden on November 07, 2007 at 14:53:50:
Carden, THis summer went through this with a "50 M that was my friend"s main tractor. It"s motor was upgraded to SM specs and it has a BUNCH of hours on it. It spent its entire life under cover unless it was working. Anyway, I started to replace the outer axle bearings and seals but decided to go ahead and do the PTO at the same time as that bearing was just a bit rough too and the seal was seeping a little. It came out really easy, allowed a good inspection/clean out point and I was able, eventually to change the inside axle bearings through the hole. Glad I pulled the PTO as there was at least an inch of semi-solid "Crud" left in the bottom of the housing AFTER I had tried to flush it. I also found parts and peices of the inside right axle bearing. Everything I do takes two or three times as long as I think it should and costs two or three times as much as I would like to pay. . .
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
