Re: 42 H new - no compression
Posted by bcPA on November 08, 2007 at 08:15:17 from (172.129.130.119):
In Reply to: 42 H new - no compression posted by G.V.J. on November 07, 2007 at 15:31:38:
I would test the valves by locking the engine at top dead center on each piston 1 at a time on the compression stroke and put air into the cylinder and see how long it takes to leak down. With the manifold off and some wd40 squirted in around the valves you will be able to see air bubles there if compression is leaking past the valves. My guess is that the valves are the problem and not the rings unless something was done wrong like oversized liners were used with standard rings.
