Re: Hydraulics on a C
Posted by Brian Schmidt on November 08, 2007 at 10:32:11 from (216.8.67.244):
In Reply to: Re: Hydraulics on a C posted by lloyd1 on November 08, 2007 at 09:46:15:
There is a valve that can go on the side of the TC where the lines connect. It was used for the FH and other rear hydraulics and or loaders. They can be found on eBay and here in the classifieds.
Or, you can purchase a bypass block that goes in between the lines and TC also (eBay is a good source for this as well). It gives ports to tap into to get hyd power. Then you need to buy a valve. Not quite as clean, but much cheaper.
