Re: Hydraulics on a C
Posted by Brian Schmidt on November 08, 2007 at 11:02:53 from (216.8.67.244):
In Reply to: Re: Hydraulics on a C posted by ScottyHOMEy on November 08, 2007 at 10:30:15:
The setup off of a Super C will fit Super A, C, Super C, etc. Anything with a hyd pump and TC rockshafts. I did it on my 49 C. I bought a Saginaw 3 point and then found this valve and tubes. Expect to spend upwards of $300 to get it, but it is much nicer and cleaner setup that the plate and separate valve. You just cannot find a small valve on the market today. So you end up with this big hunk of iron strapped to the side of the tractor.
