Re: 300 Starter
Posted by D Slater on November 08, 2007 at 16:03:23 from (71.164.57.221):
In Reply to: 300 Starter posted by Scott300IA on November 08, 2007 at 06:47:54:
Yes, the only problem you may have is that part of the 450 gasoline were 12 volt starter. If you still have a 6 volt 300 it may not crank a 12 volt starter to good. If you are using 12 V on the 300 or both starters are 6 V, bolt it on and go. The original 12 volt 450 starters used a extra terminal on the selonoid to send current past the resistor to coil, but that won't effect you putting it on a 300.
