Re: polarizing a regulator
Posted by John T on November 08, 2007 at 19:39:41 from (66.244.83.147):
In Reply to: polarizing a regulator posted by Gary Davenport gd on November 08, 2007 at 19:31:15:
Its the generator you Polarize instead of the regulator. Before start up momentarily flash jump a wire from BAT on the VR over to its ARM/GEN terminal or else from BAT on the VR (or any other hot ungrounded battery post feed for that matter) direct to the gennys ARM post n you ought to get a spark.
John T
