Hold your had hand over the throat of the carburetor and see there's good suction on your hand and your hand should be wet with gas. You need good intake maifold vacuum to pull that atomized fuel into the engine. Good rings and valves seating good all contribute to good a vacuum. Check your intake manifold bolts to see if they're snug. Check that compression to see what it is, worn cylinders and rings can cause low compression and weak manifold vacuum. Hal
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
