Should I pop the valve cover?
Posted by Mike CA on November 10, 2007 at 10:28:56 from (69.105.151.89):
One thing I haven't done is pop off the vavle cover to inspect underneath. The reason I haven't is because I have no idea what I'd be looking at. But I was reading something that said if a tractor has been sitting a while, you should pour oil over the rockers or something like that.
Should I pull the cover before I try to start it? If so, what should I inspect for while I'm under there? What should I do to prep the area before starting the tractor which hasn't run in 10 years?
