Re: Farmall M Steering Shaft
Posted by Nebraska Cowman on November 10, 2007 at 15:21:40 from (65.162.146.41):
In Reply to: Farmall M Steering Shaft posted by Zach Bouchard on November 10, 2007 at 14:52:02:
Take the clamp bolt out of the rear of the universal joint. Take the cap off the front of the steering box. (unscrews with a big pipe wrench) Turn the shaft a little and it will start forward. Then as the universal comes off you can get the woodruff key out of the slot so the shaft can pass through the bearing.
