Re: Farmall M Steering Shaft
Posted by poogie on November 10, 2007 at 15:23:11 from (204.8.190.97):
In Reply to: Farmall M Steering Shaft posted by Zach Bouchard on November 10, 2007 at 14:52:02:
There is only one way! Remove the screw-on bearing cap on the extreme front of the housing and then remove the universal joint from the other end of shaft. Really quite easy!
