Posted by msb on November 10, 2007 at 18:48:23 from (76.2.80.119):
Posted this over at Case- no response. Doesn't some IH tractors use the same pump? Someone mentioned the possibility of a broken pin in the pump? TIA,bob Long story /short version. Primary filter plugged, finally just removed it. Replaced the next two filters-both full of crud.Also finally got system primed-gravity. Pulled the transfer pump--O.K..Still no start. Pulled the governor cover. Linkage was stuck, freed it up. Still no start. Took the side cover off. Nothing turned when engine was cranked. I assume the gear I see turns the distributor? Sale in in morning. I assume something inside the pump is broken? I hate to get beat.Trouble at every turn.I shall overcome. lol. Any help is appreciated. E-mail is open.Thanks, bob
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
