I just read the posts below and all are good ideas, but I saw you already pulled the head off so what I was going to add won"t help now. If you can get hold of a radiator test cap with an air pump on it and pull the oil pan off you can see if there might be a crack or leak in the bottom of the block. With about 15 lbs pressure on the water it will force it out and you can see if it is coming from a bore past a piston or from the block or down the pushrod or drain holes. If a head inspection fails to find it you could put the head back on with the old gasket cleaned up good of course and test it. If you use a new gasket and it leaks, you will have to put on another new gasket when you put it back together after fixing the problem. If you have a non pressure radiator it may not work with a tester since the rad neck is different.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
