Posted by Bob on November 11, 2007 at 08:52:58 from (69.178.229.154):
In Reply to: tune up posted by Willie R Adkins on November 11, 2007 at 07:20:51:
Do you have the points set correctly @ .013" when fully OPEN?
Have you cleaned them with electrical contact cleaner to remove any oil and dust that may be on them, preventing good contact?
Did you mess something up in the points/condensor area, causing a short to ground? How about the wire to the condensor... is that in place around the condensor stud?
Did you have the little cover off that surrounds the rotor shaft, and get the timing of the little gears inside messed up?
Do you have access to the IH Blue Ribbon Service Manual for mags?
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
