Re: Farmall M brakes
Posted by D Slater on November 11, 2007 at 09:21:05 from (71.164.57.221):
In Reply to: Farmall M brakes posted by John from upstate New Yor on November 11, 2007 at 06:47:33:
Go to the Case IH web site parts catalog, put in farmall for model then go to M then chassis then look at # 238 disc brakes special and see if thats what you have. If you look at tractor it will have 3 bolts holding brake housings on and brake pedals will be like drum brake pedals.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
