Re: Farmall A temp gauge
Posted by n9lhm on November 11, 2007 at 09:38:44 from (70.224.32.94):
In Reply to: Farmall A temp gauge posted by bigr on November 11, 2007 at 05:34:00:
On my A (no water pump) I drilled and tapped a hole in the upper water elbow to screw the gauge sensor into. I didn"t want to put it in the lower elbow like original since it will never read anything but cold there if you don"t have radiator shutters.
