Re: Alternator for an H
Posted by tackhammertime on November 11, 2007 at 18:21:15 from (74.227.204.157):
In Reply to: Alternator for an H posted by Gleanerguy on November 11, 2007 at 17:38:20:
I pulled all the Generator, voltage regulator and wires out of mine last month. Bought a alternator with smaller pulley for a ford tractor from the local tractor dealer, belt from NAPA 30", built me a bracket out of metal from Lowes,and run 1 wire from the alternator to the Amp gage then to the battery. Works great didn't cut the hood and it fits between the valve cover and the hood. Can't even see it unless you look under the hood. Mine had already been converted to 12V with generator, voltage regulator, light bulbs, and ballast resistor. You will need these things if you are still 6V. About $120.00 for the change over
