Re: B timing
Posted by scotty on November 12, 2007 at 05:02:18 from (199.231.49.128):
In Reply to: B timing posted by Terry Therneau on November 12, 2007 at 04:19:11:
Mornin Terry,
Loosen the mag slightly and push the top of the mag towards the block. Rotate the engine by crank until you are on TDC again using the finger in the #1 plug hole and checking the DC line on the flywheel. When you have determined your on TDC again slowly rotate the magneto away from the block until the impulse coupling snaps. At that point tighten the mag in that position and replace your #1 plug and attempt to start your engine. Your rotor at that point should be just past the #1 spot on tour cap.
scotty
