Posted by Farmall Ed on November 12, 2007 at 05:14:24 from (69.245.54.29):
In Reply to: B timing posted by Terry Therneau on November 12, 2007 at 04:19:11:
Terry, I just timed an H last week and the book says when you set the roter to # 1 plug in the distributer to rotate the mag toward the engine as far as possible and tighten it enough so it dont move. Then crank the engine until you have # 1 at top center Compression again, Then rotate the mag outward until the impulse coupling trips. Should be timed. Hope this works for your B. Ed
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
