Re: Whats going on here?
Posted by Stan(VA). on November 12, 2007 at 05:28:43 from (4.249.228.234):
In Reply to: Whats going on here? posted by scott#2 on November 11, 2007 at 17:32:16:
Scott,
Nice pictures. Just out of curiosity I would temporarily swap the #1 & #2 rods to see if the problem follows the piston or the rod. (ie: put the number 2 piston on your number 1 rod, and numer 1 piston on number 2 rod and swap the rods between number 1 and 2 crank journals) Idea is keep the pistons where they are and just move the rods. I have a bent rod sitting downstairs now that would show like the problem you see.
If the problem is the rod, replace it and follow the advice you had earlier about checking for head clearance. My gut feeling is that the small amount of twist you see to the tops is alright if it is consistant. Your 140 head has the small combustion chanber so if you are at all concerned, definately test for clearance.
If the problem stays with the piston, I would send them back to the supplier/manufacturer.
Just a note, I don"t ever recommend saving the pin bushings when you replace the sleeves and pistons. And Hugh, that is definately the later 140/240 series block as you can see from the flat in the lower left picture. Count his head bolt positions... Just a gentle reminder that the I&T manual has an error.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
