Re: setting points
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by IHank on February 22, 2000 at 09:00:58 from (167.142.18.25):
In Reply to: setting points posted by tony on February 22, 2000 at 06:58:56:
The trick is to ignore degrees of dwell, and instead work & think using percentage of dwell. That skips the confusion about number of cylinders and correct degrees dwell number. Adjust the points to give around 60% - 66% dwell. Once you got the points adjusted clean off the timing marks and pointer. Look up the timing specification and follow any procedure given to adjust timing. At an engine idle speed below what kicks in the centrifugal spark advance carefully twist the distributor housing to bring the pointer to the proper mark. Snug down the distributor clamp screw. Like Red sez, run the engine speed up and down and observe that the timing advances as engine speed goes up and returns to the set point at slow idle. If the timing does not change smoothly, then you need to do some work on the centrifugal advance mechanism- weak springs, worn pivots and gummy lube are common sources of trouble. Good luck!
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
