Re: B timing
Posted by ddg on November 13, 2007 at 06:18:29 from (66.45.132.161):
In Reply to: B timing posted by Terry Therneau on November 12, 2007 at 04:19:11:
If you had the mag out, and had it opened up or rebuilt,you may have got the little rotor drive gear one tooth off. Take the distributer cap off, and see where the rotor is pointing when it trips. If you"ve rotated the mag as far as you can go in it"s timing slot, and still won"t trip at the right time/position, that might be the problem.
